[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Tue May 4 14:28:25 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by loldrup):
 Ok robe.
 I have upgraded GEOS only as described above, SELECT
 postgis_full_version() returns: "POSTGIS="1.4.1" GEOS="3.2.2-CAPI-1.6.2"
 PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS"
 But the problem still exists:
 2010-05-04 23:19:12 CEST   3296 LOG:  server process (PID 3480) was
 2010-05-04 23:19:12 CEST   3296 HINT:  See C include file "ntstatus.h" for
 a description of the hexadecimal value.
 2010-05-04 23:19:12 CEST   3296 LOG:  terminating any other active server
 processes
 If U supply me with symbol files, I can produce a more complete stack
 trace if needed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:3>
