[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Fri May 7 10:16:16 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by loldrup):
 Paul, what do U exactly means with "on a pgsql"?
 Anyways, I just restored the dbase, changed shared_buffers from 32MB to
 64MB, ran the Jmeter test (that probably would die within 1000-2000
 samples), and it ran for 50.000 samples untill I stopped it (my
 workstation becomes totaly unusable (m$)).
 Are we seeing a "out of memory situation"?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:13>
