[postgis-devel] [PostGIS] #509: Invalid Charset Encoding breaks Win32 GUI
PostGIS trac at osgeo.org
Fri May 7 11:49:06 PDT 2010
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:
Comment (by robe):
 I don't think its the vcc build libiconv at fault.
 I think I had replaced my local postgresql bin with the mingw, but I just
 tried with the one that gets packaged with PgAdminIII which is the way I
 normally use it and it works fine with that one.  Besides I would expect
 we would have similar issues with the command line if that were the case.
 Are you sure your source directory isn't dirty with some old files.
 For perspective I pulled out an old copy of a shp2pgsql-gui and it gives
 this error
 with your file.
 Failed in pgui_exec(): ERROR:  invalid byte sequence for encoding "UTF8":
 0xb3
 I presume that is the error you are getting?  I thought maybe it was the
 encoding of the database that would make a difference -- but works fine
 for me against UTF8 encoded as well as win1252 encoded database.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/509#comment:9>
