[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Fri May 7 13:31:33 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by loldrup):
 Running on the clean restored database, JMeter test has been running 2
 hours - now at 374.000 samples, and still running - still using the 64MB
 shared_buffes setting. Memory consumption of the 5 backend's now at 61MB
 each - looks like a leak.
 If it's a leak, why does changing table data sometimes remove the leak? -
 anyways in this ballgame anything is possible!
 Ill just leave it running over night... it's getting late in Denmark...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:17>
