[postgis-devel] mingw autotools
Paragon Corporation lr at pcorp.us
Tue May 11 18:24:51 PDT 2010
Paul,
Which version of GEOS are you configuring?
Like I mentioned I haven't had problems with GEOS <= 3.2.2 , but the 3.3.0
just can't build under mingw.  Which I suspect you are running into the same
issues?
I think it builds fine under my VS /VS Express environments last I checked.
Which  of course vastly limits my ability to test anything in the PostGIS
2.0 trunk (aside from I have issues - can't build even against old GEOS the
trunk under mingw)
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, May 11, 2010 7:40 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] mingw autotools
Winguys and wingals,
Trying to follow the generic build instructions on the Wiki, I've found that
I simply cannot use the mingw/msys autotools to generate a GEOS configure
file. If I generate one on OSX and copy it over I can build GEOS, but the
mingw tools create a configure which then fails to detect int64 (and god
knows what else) which leads to various failures.
I can hack around this limitation as I always have, but I'm wondering if
there's some unwritten magic you've got going on. I used the instructions,
but I got no love.
P.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
