[postgis-devel] mingw autotools
Paragon Corporation lr at pcorp.us
Thu May 13 00:53:41 PDT 2010
I forget whether I had upgraded MingW or just the Msys and gcc.  I think my
problems might have stemmed from my gcc and Msys upgrades.  All I know is
after that, I could no longer compiled GEOS 3.2 nor libxml so had to revert
to my prior backup.  Unfortunately I don't have my old install handy to
check.
Thanks,
Regina
____________________
From: postgis-devel-bounces at postgis.refractions.net
[postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
[pramsey at opengeo.org]
Sent: Wednesday, May 12, 2010 11:57 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] mingw autotools
I put 3.1.6 on my new box and have had no luck. With 3.1.4, things did seem
to work on the old box. Does that ring a bell?
P
On Tue, May 11, 2010 at 11:54 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> Yes that sounds familiar.  Haven't been able to build the GEOS 3.2+
> with the newer MingW (I could build 3.1 with the newer), so I had to
> scrap my newer install and revert when started working on 1.5.
>  Even gdal which WKT Raster relies on technically doesn't support
> MingW, though it works with some hacking.
> Anyway.  For 2.0 I want a clean start and go VS/VS Express all the way.
> Thanks,
> Regina
> -----Original Message-----
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Paul Ramsey
> Sent: Tuesday, May 11, 2010 10:13 PM
> It got more confusing, unfortunately. I had an older VM configured
> exactly to the old wiki page and the autotools there spit out a usable
> configure. So the problem (maybe?) is with moving up to the latest
> minor version of MingGW? So I don't know what the answer is except
> that building with MinGW is impossibly confusing. If VCC can offer a
> saner build situation it might be worth the time spent to just suck it
> up and go to a pure VCC build. Proj and GEOS already build in VCC as does
pgsql so it's just postgis to do...
> P.
> On Tue, May 11, 2010 at 6:24 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Paul,
>> Which version of GEOS are you configuring?
>> Like I mentioned I haven't had problems with GEOS <= 3.2.2 , but the
>> 3.3.0 just can't build under mingw.  Which I suspect you are running
>> into the same issues?
>> I think it builds fine under my VS /VS Express environments last I
> checked.
>> Which  of course vastly limits my ability to test anything in the
>> PostGIS 2.0 trunk (aside from I have issues - can't build even
>> against old GEOS the trunk under mingw)
>> Thanks,
>> Regina
>> Paul Ramsey
>> Sent: Tuesday, May 11, 2010 7:40 PM
>> Subject: [postgis-devel] mingw autotools
>> Winguys and wingals,
>> Trying to follow the generic build instructions on the Wiki, I've
>> found that I simply cannot use the mingw/msys autotools to generate a
>> GEOS configure file. If I generate one on OSX and copy it over I can
>> build GEOS, but the mingw tools create a configure which then fails
>> to detect int64 (and god knows what else) which leads to various
failures.
>> I can hack around this limitation as I always have, but I'm wondering
>> if there's some unwritten magic you've got going on. I used the
>> instructions, but I got no love.
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant to
Massachusetts law. It is intended solely for the addressee. If you received
this in error, please contact the sender and delete the material from any
computer.
