[postgis-devel] mingw autotools
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu May 13 02:34:24 PDT 2010
Paul Ramsey wrote:
> Winguys and wingals,
> Trying to follow the generic build instructions on the Wiki, I've
> found that I simply cannot use the mingw/msys autotools to generate a
> GEOS configure file. If I generate one on OSX and copy it over I can
> build GEOS, but the mingw tools create a configure which then fails to
> detect int64 (and god knows what else) which leads to various
> failures.
> I can hack around this limitation as I always have, but I'm wondering
> if there's some unwritten magic you've got going on. I used the
> instructions, but I got no love.
> P.
 From memory, the version of autotools supplied with MSYS dates from the
dawn of time and so the first thing I did on my MingW/MSYS setup was to
install the latest version of autotools which pretty much solved everything.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
