[postgis-devel] Problems compiling PostGIS under MinGW
Jorge Arévalo jorge.arevalo at deimos-space.com
Thu May 27 07:55:11 PDT 2010
I'm compiling PostGIS and all needed stuff in MinGW following this:
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile (BTW, I've made
two little changes in this wiki page).
My problem is starting postgreSQL server. If I execute:
/c/postgres/bin/pg_ctl.exe -D /c/postgres/data -l logfile start
I get the error message:
This application has failed to start because libpq.dll was not found.
Re-installing the application may fix this problem mingw
The dll file is in its place (/c/postgres/lib), and I've compiled
everthing, several times. I can't provide a log file because is not
generated
Any clues? Regina, I think you provide PostGIS Windows builds, what
enviroment are you using?
Thanks in advance, and best regards,
Jorge Arévalo
DEIMOS Space
Internet & Mobilty Division
Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
28760 Tres Cantos (Madrid)
Tel: +34 91 806 34 50 - ext: 155
