[postgis-devel] PostGIS in a separate schema
Paul Ramsey pramsey at opengeo.org
Thu May 27 09:33:26 PDT 2010
The main killer was this need for a custom search path. There are
certainly many potential 'pros' to using a separate schema.
P.
On Thu, May 27, 2010 at 12:29 PM, George Silva <georger.silva at gmail.com> wrote:
> All you need, if I'm not mistaken, is to add the schema to your default
> schema search and everything should be fine?
> Can anyone confirm this?
> George
> On Thu, May 27, 2010 at 1:27 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
>> Hi,
>> Was it ever considered to put PostGIS functions and everything related to
>> PostGIS in a "PostGIS" schema?
>> The only/main pro I see is to make a PostGIS enabled database cleaner but
>> maybe there are killer cons?
>> Pierre
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> George R. C. Silva
> Desenvolvimento em GIS
> http://blog.geoprocessamento.net
