[postgis-devel] [PostGIS] #501: [wktraster] Implement a ST_Value based on world coordinates instead of raster coordinates
PostGIS trac at osgeo.org
Thu May 27 12:57:02 PDT 2010
raster coordinates
  Reporter:  pracine    |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Pierre,
 Not sure what you mean.
 st_value(rast raster, band integer, pt geometry)
 would be the one I would use for world coordinates.  The other one is
 totally unnecessary.
 The common use case is
 SELECT r.value,st_value(r.rasst, 1, ptgeom) as val
 FROM rastetable INNER JOIN geomtable  ON ST_Intersects(rastertable.rast,1,
 geomtable.ptgeom);
 Can't really think why one would ever want a
 st_value(rast raster, band integer, x float, y float)
 It would just add unnecessary confusion and function bloat to me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/501#comment:3>
