[postgis-devel] [PostGIS] #484: [wktraster] rtpostgis.sql.in.c using old style 1.3 syntax and other arcane stuff
PostGIS trac at osgeo.org
Mon May 31 13:45:03 PDT 2010
stuff
  Reporter:  robe       |       Owner:  pracine
      Type:  task       |      Status:  new
  Priority:  low        |   Milestone:  WKTRaster Future
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by pracine):
 Need more info to do 2, 3 and 5:
 2) Is there any rule to camel case the function names? postgis.sql has a
 mixture of camelcase/lowercase
 3) postgis.sql has a mixture of with/without cost. What is the rule?
 5) Again what is the rule? Should we blindly replace all ' with $$ in all
 type of function (C and SQL). All plpgsql functions now use $$.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/484#comment:4>
