[postgis-devel] [PostGIS] #661: Type info of geography columns incomplete - pg_dump output wrong
PostGIS trac at osgeo.org
Wed Nov 17 01:56:35 PST 2010
 Reporter:  tider              |       Owner:  pramsey
     Type:  defect             |      Status:  new
 Priority:  medium             |   Milestone:  PostGIS 1.5.3
Component:  postgis            |     Version:  1.5.X
 Keywords:  geography pg_dump  |
 Steps to reproduce (using interactive psql):
 test=# CREATE table test (geom geography(GEOMETRY,4326));
 CREATE TABLE
 test=# \d test
          Table "public.test"
  Column |      Type       | Modifiers
  geom   | geography(4326) |
 Note the wrong type "geography(4326)", it should be
 "geography(GEOMETRY,4326)". This type info is used by pg_dump as well,
 resulting in a failing CREATE TABLE statement.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/661>
