[postgis-devel] [PostGIS] #662: Make POLYGONM geometry crashes server
PostGIS trac at osgeo.org
Thu Nov 18 10:35:39 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Paul,
 I didn't test your very very last set of changes, so this might be fixed.
 Your bulk load of changes didn't get too far in my maze of traps before
 setting off alarms.
 Can you run the below and see if it works on your system.  On my 9.1
 alpha2 install it crashes the service.
 CREATE TABLE pgis_garden (gid serial);
 CREATE TABLE
         SELECT
 AddGeometryColumn('pgis_garden','the_geom',ST_SRID(the_geom),GeometryType(the_geom),ST_CoordDim(the_geom))
                         FROM ((SELECT
 ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326)))
 As the_geom
                 FROM generate_series(-10,50,20) As i
                         CROSS JOIN generate_series(50,70, 20) As j
                         CROSS JOIN generate_series(1,2) As m
                         ORDER BY i, j, m, i*j*m
                         )) As foo limit 1;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/662>
