[postgis-devel] [PostGIS] #664: PointArray Side Effect
PostGIS trac at osgeo.org
Mon Nov 22 12:38:26 PST 2010
 Reporter:  colivier  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
Comment(by nicklas):
 I looked some into the 3DDistance case and found that the problem was not
 in the distance functions, but in ST_Expand.
 The failure is trigged by:
 SELECT ST_Expand('POINT(1 1)'::geometry,5);
 The regression tests passes if ST_3DDWithin test is replaced by
 _ST_3DDWithin
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/664#comment:1>
