[postgis-devel] [PostGIS] #666: ST_DumpPoints is not null safe
PostGIS trac at osgeo.org
Thu Nov 25 01:05:52 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.3
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by yabo):
 Here's a patch. I'm not sure of what should be in the regress test though.
 Empty lines ? NULL ? I can't run make check from where I am now.
 Index: postgis/postgis.sql.in.c
 --- postgis/postgis.sql.in.c    (revision 6203)
 +++ postgis/postgis.sql.in.c    (working copy)
 @@ -1950,6 +1950,10 @@
    -- Special case collections : iterate and return the DumpPoints of the
 geometries
 +  IF (the_geom IS NULL OR ST_IsEmpty(the_geom)) THEN
 +    RETURN;
 +  END IF;
    IF (ST_IsCollection(the_geom)) THEN
      i = 1;
 Index: regress/dumppoints.sql
 --- regress/dumppoints.sql      (revision 6203)
 +++ regress/dumppoints.sql      (working copy)
 @@ -157,3 +157,19 @@
          )'::geometry AS geom
      ) AS g
    ) j;
 +SELECT path, ST_AsText(geom)
 +FROM (
 +  SELECT (ST_DumpPoints(g.geom)).*
 +  FROM
 +    (SELECT NULL::geometry AS geom
 +    ) AS g
 +  ) j;
 +FROM (
 +  FROM
 +    (SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry AS geom
 +    ) AS g
 +  ) j;
 Index: regress/dumppoints_expected
 --- regress/dumppoints_expected (revision 6203)
 +++ regress/dumppoints_expected (working copy)
 @@ -82,3 +82,5 @@
  {5,1,2,2}|POINT(5 6)
  {5,1,2,3}|POINT(6 6)
  {5,1,2,4}|POINT(5 5)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/666#comment:1>
