[postgis-devel] [PostGIS] #669: ST_Intersects(geometry, empty) not returning false
trac at osgeo.org
Mon Nov 29 05:13:14 PST 2010
Reporter: wiki | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: ST_Intersects EMPTY |
The wiki
http://trac.osgeo.org/postgis/wiki/DevWikiEmptyGeometry
states that ST_Intersects(geometry, empty) should return false, but it
results in an error:
ERROR: Relate Operation called with a LWGEOMCOLLECTION type. This is
unsupported.
HINT: Change argument 2: 'GEOMETRYCOLLECTION EMPTY'
select * from some_table where "intersects"("geometry"('POINT(40.0
10.0)'), tablerow_area);
will not work if any tablerow_area is "geometry"('POLYGON EMPTY').
Ticket URL: <http://trac.osgeo.org/postgis/ticket/669>
