[postgis-devel] TRIANGLE
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 5 16:10:30 PDT 2010
Unless I'm wrong, this is just a really stupid definition for the TRIANGLE WKB (from the "modularized" ISO draft)
WKBTriangle
  byte byteOrder;
  static uint32  wkbType = 17;
  uint32  numRings;
  LinearRing rings[numRings]
I mean, it's a triangle right? How many rings does it have? And how many points are in that ring? At a minimum it should be reduced to:
WKBTriangle
  byte byteOrder;
  LinearRing ring;
At least then only the number of points would be redundant information.
P.
