[postgis-devel] [PostGIS] #623: Can't compile under mingw anymore BYTE_ORDER undeclared
PostGIS trac at osgeo.org
Fri Oct 8 06:26:44 PDT 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw    |
 Since I think yesterday or day before been getting this error.
 We'll check our other mingw environment later to make sure its not some
 configuration thing we added by accident. Also tried blowing out our
 subverson and redownloading, but that did not help.
 lwin_wkb.c: In function `lwgeom_from_wkb_state':
 lwin_wkb.c:596: error: `BYTE_ORDER' undeclared (first use in this
 function)
 lwin_wkb.c:596: error: (Each undeclared identifier is reported only once
 lwin_wkb.c:596: error: for each function it appears in.)
 lwin_wkb.c:596: error: `LITTLE_ENDIAN' undeclared (first use in this
 function)
 make[1]: *** [lwin_wkb.o] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/623>
