[postgis-devel] [PostGIS] #382: PostGIS native VC++ / Express build
PostGIS trac at osgeo.org
Fri Oct 8 12:16:28 PDT 2010
 Reporter:  robe         |       Owner:  robe
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 We are not having much success with this.  So we will give up for now and
 hopefully will have better luck with MSys64.  I was also thinking we
 really need to support Msys64 anyway.  It seems unfair to require someone
 to go out and by VS professional just so they can compile PostGIS under
 windows for 64-bit.  It doesn't seem the Express supports 64-bit.  Granted
 we should at some point support VS/VC++, but I don't think (Leo and I) are
 capable of it giving our limited experience with C and C++.
 Mat -- tried to follow your directions -- but not much luck.
 We started notes on it -- not finished --
 http://trac.osgeo.org/postgis/wiki/DevWikiWinVC_15
 Even on 32-bit not having much success compiling PostGIS 1.5.3SVN. We get
 errors such as below
 /Od /I "C:\Projects\Geos\geos-3.2.2win\include" /I
 "C:\Projects\PostGIS\branches\postgis-1.5.3win\build\msvc80\..\..\platform\win32"
 /D "WIN32" /D "_DEBUG" /D "_LIB" /D
 "_USE_MATH_DEFINES" /D "_UNICODE" /D
 "UNICODE" /Gm /EHsc /RTC1 /MDd /Fo"Debug\\"
 /Fd"Debug\vc90.pdb" /W3 /c /Wp64 /ZI /TC
 "..\..\..\liblwgeom\wktparse.tab.c"
 "..\..\..\liblwgeom\vsprintf.c"
 "..\..\..\liblwgeom\ptarray.c"
 "..\..\..\liblwgeom\measures.c"
 "..\..\..\liblwgeom\lwutil.c"
 "..\..\..\liblwgeom\lwtree.c"
 "..\..\..\liblwgeom\lwspheroid.c"
 "..\..\..\liblwgeom\lwsegmentize.c"
 "..\..\..\liblwgeom\lwpoly.c"
 "..\..\..\liblwgeom\lwpoint.c"
 "..\..\..\liblwgeom\lwmsurface.c"
 "..\..\..\liblwgeom\lwmpoly.c"
 "..\..\..\liblwgeom\lwmpoint.c"
 "..\..\..\liblwgeom\lwmline.c"
 "..\..\..\liblwgeom\lwmcurve.c"
 "..\..\..\liblwgeom\lwline.c"
 "..\..\..\liblwgeom\lwgunparse.c"
 "..\..\..\liblwgeom\lwgparse.c"
 "..\..\..\liblwgeom\lwgeom_api.c"
 "..\..\..\liblwgeom\lwgeom.c"
 "..\..\..\liblwgeom\lwgeodetic.c"
 "..\..\..\liblwgeom\lwcurvepoly.c"
 "..\..\..\liblwgeom\lwcompound.c"
 "..\..\..\liblwgeom\lwcollection.c"
 "..\..\..\liblwgeom\lwcircstring.c"
 "..\..\..\liblwgeom\lwalgorithm.c"
 "..\..\..\liblwgeom\lex.yy.c"
 "..\..\..\liblwgeom\g_util.c"
 "..\..\..\liblwgeom\g_serialized.c"
 "..\..\..\liblwgeom\g_ptarray.c"
 "..\..\..\liblwgeom\g_geometry.c"
 "..\..\..\liblwgeom\g_coord.c"
 "..\..\..\liblwgeom\g_box.c"
 "..\..\..\liblwgeom\box2d.c"
 Creating command line "cl.exe
 @"c:\Projects\PostGIS\branches\postgis-1.5.3win\build\msvc80\liblwgeom\Debug\RSP00002120725080.rsp"
 /nologo /errorReport:prompt"
 </pre></table><table width=100% bgcolor=#DFDFE5><tr><td><font face=arial
 size=+2>
 Output Window
 </font></table><table width=* cellspacing=0 cellpadding=0><tr><td width=0
 bgcolor=#EDEDF5> </td><td width=0 bgcolor=#FFFFFF> </td><td
 width=*><pre>Compiling...
 cl : Command line warning D9035 : option 'Wp64' has been deprecated and
 will be removed in a future release
 box2d.c
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(177) :
 error C2054: expected '(' to follow 'va_dcl'
 error C2085: 'uchar' : not in formal parameter list
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(186) :
 error C2085: 'BOX2DFLOAT4' : not in formal parameter list
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(193) :
 error C2085: 'BOX3D' : not in formal parameter list
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(201) :
 error C2061: syntax error : identifier 'BOX3D'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(238) :
 error C2059: syntax error : '}'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(316) :
 error C2016: C requires that a struct or union has at least one member
 error C2061: syntax error : identifier 'uchar'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(319) :
 error C2061: syntax error : identifier 'dims'
 error C2059: syntax error : ';'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(322) :
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(333) :
 error C2061: syntax error : identifier 'POINTARRAY'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(336) :
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(340) :
 error C2143: syntax error : missing '{' before '*'
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(354) :
 error C2143: syntax error : missing ')' before '*'
 error C2371: 'POINT4D' : redefinition; different basic types
 c:\projects\postgis\branches\postgis-1.5.3win\liblwgeom\liblwgeom.h(303) :
 see declaration of 'POINT4D'
 And it goes on and on. Also not sure where we would put the libxml
 dependency that became a requirement in 1.5.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/382#comment:5>
