[postgis-devel] [PostGIS] #610: [raster] Can't build with raster
PostGIS trac at osgeo.org
Wed Oct 13 09:03:19 PDT 2010
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 Regina: The patch is working for me. And yes, I missed these 2 lines. I
 think it worked before because I've defined LD_LIBRARY_PATH pointing to
 gdal directory in my enviroment. Many thanks and sorry. I'll commit the
 changes.
 Pierre: I just wanted to keep raster stuff totally separated from the rest
 until official 2.0 release. But ok, maybe it's a bit... too much. I'll
 modify the scripts to avoid the make rt-install part, and simply install
 the raster part with "make install" if "--with-raster" option is provided.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/610#comment:4>
