[postgis-devel] Something wrong with build
Paragon Corporation lr at pcorp.us
Wed Oct 13 11:59:54 PDT 2010
Kevin,
For what its worth, doing the
Make comments
On our Xp box takes about 2 minutes.  We are running a newer version of
xsltproc than you.
-- ours is --
Using libxml 20703, libxslt 10124 and libexslt 813
xsltproc was compiled against libxml 20701, libxslt 10124 and libexslt 813
libxslt 10124 was compiled against libxml 20701
libexslt 813 was compiled against libxml 20701
--- end --
When I cheat by copying in a blank  postgis_aggs_mm.xml   -- it takes about
15-30 seconds to build both the postgis_comments.sql and postgis_raster.sql
I suppose this may be my fault :( -- the postgis_aggs_mm.xml.xsl is doing a
tad bit more than it used to in PostGIS 1.5.
2 more columns for the function matrix (so much for my dreams of having a
raster function matrix - though that wouldn't be quite as useful anyway)
Another 50 someodd functions and an additional what's new section (hmm a
what's new broken out into two because we have too many new functions and
enhanced functions)
Our manual for PostGIS 2.0 is already about 100 pages longer than the
PostGIS 1.5.  At this rate, we might have to start breaking it out into
volumes :)
 How does the speed compare to building PostGIS 1.5 by the way?  I imagine
its much longer.
Thanks,
Regina
-----Original Message-----
From: Kevin Neufeld [mailto:kneufeld at refractions.net]
Sent: Wednesday, October 13, 2010 1:32 PM
To: Paragon Corporation
Cc: PostGIS Development Discussion
Subject: Re: Something wrong with build
  Right, so the current autobuild process is taking about 60 minutes to
complete.
The build itself happens within minutes.  Building the documentation on the
other hand is what is dragging the process out.
# takes about 20 minutes
make -e chunked-html 2> doc-errors.log
# takes about 15 minutes
make comments 2>> doc-errors.log
# takes about 22 minutes
make pdf
During chuck-html task, it looks like we're stalling on this command (stalls
for about 10 minutes, idle cpu, i/o):
/usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml >
postgis_aggs_mm.xml
and this (stalls here too for about 10 minutes):
/usr/bin/xsltproc \
   --param section.autolabel 1 \
   --param section.label.includes.component.label 1 \
   --param chunk.section.depth 0 \
   --param generate.section.toc.level 1 \
   --param funcsynopsis.style ansi \
   --param admon.graphics 1 \
   --param admon.textlabel 0 \
   --param simplesect.in.toc 0 \
   --param use.id.as.filename 1 \
   --param chunk.quietly 1 \
   --stringparam html.stylesheet style.css  \
   --output html/ \
   --stringparam saxon.character.representation decimal \
   /usr/share/sgml/docbook/xsl-stylesheets/html/chunk.xsl \
   postgis-out.xml
Then, on the comments task (taking about 15 minutes):
/usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis.xml >
postgis_comments.sql /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl
postgis.xml > raster_comments.sql
The pdf task used to take only 5-10 minutes, now we're up to 22 minutes,
stalling on the dblatex command.
Anyone have ideas why xsltproc is getting slower and slower?  The build
machine is a standalone PostGIS build box ...  load average is minimal.
Is it just the configuration / software versions on this box?  Are others
able to build the docs in a reasonable amount of time?
For reference:
$ xsltproc --version
Using libxml 20626, libxslt 10117 and libexslt 813 xsltproc was compiled
against libxml 20626, libxslt 10117 and libexslt 813 libxslt 10117 was
compiled against libxml 20626 libexslt 813 was compiled against libxml 20626
Cheers,
Kevin
On 10/12/2010 2:06 PM, Paragon Corporation wrote:
> Kevin,
> Can you take a look and see what is taking the build so long.
> http://office.refractions.net:1500/view/PostGIS%20Trunk/job/PostGIS-tr
> unk-bu
> ild/
> Last  change was trying to include raster_comments build in the
> make comments
> I think it broke last time I tried that too so had to roll back the
change.
> Not giving an error just stalling as far as I can tell.
