[postgis-devel] Something wrong with build
Olivier Courtin olivier.courtin at oslandia.com
Wed Oct 13 14:57:44 PDT 2010
On Oct 13, 2010, at 11:40 PM, Kevin Neufeld wrote:
> Ok, after some troubleshooting, I've traced the problem to this
> commit.
> http://trac.osgeo.org/postgis/changeset/5466/trunk/doc/postgis.xml
Ok the idea was to bring MathML to DocBook schema and then
to be able to validate mml elements from using_postgis_dataman.xml
> If I revert this change,
>  make chunked-html jumps from 20 minutes to 1.
>  make comments     jumps from 15 minutes to 0.
>  make pdf          jumps from 22 minutes to 8.
> Perhaps the corresponding issue (#471) should be reopened and
> different solution found.
The ticket should be reopened anyway as several DocBook code are
no more compliant to schema.
Olivier
