[postgis-devel] Something wrong with build
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Oct 14 04:18:30 PDT 2010
Paragon Corporation wrote:
> Have any idea how long its been going on.  I could take out some of the
> sections I added to  postgis_aggs_mm.xml.xsl  to see if that improves
> things, but the documentation however you look at it is significantly larger
> in 2.0.  Just the Raster section alone adds about 50 pages.
> Though like I mentioned on our local doesn't take that long (probably about
> 2 minutes at most), but we don't have the doc book dtd etc included so
> perhaps the extra dtd validation is eating up resources.
Ah yeah, I think I had a similar problem on my laptop here and it was
because I didn't have the relevant schemas installed locally and so it
was downloading them from the internet which was extremely slow.
Kevin, can you check with tcpdump (or equivalent) on the build box to
see if it is in fact downloading the schemas from source for every
build? If so, most distros should have a pre-built package lying around
which when installed should solve the issue.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
