[postgis-devel] [PostGIS] #628: gdal2raster -F switch broken?
PostGIS trac at osgeo.org
Fri Oct 15 11:25:08 PDT 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Is the -F switch that inserts the file name to raster table broken or am I
 doing it wrong.
 I did this
 python gdal2raster.py -r Vietnam\dted\*\*.dt0 -t ch13.vietelev  -s 4326 -k
 50x50 -F -I -o vietelev.sql
 and to my dissatisfaction it created an invalid sql file with stuff like
 INSERT INTO "ch13"."vietnam_elev" ( filename, rast ) VALUES ( ('<type
 'file'>')::text, ('0....
 Seemed to work fine without the -F switch, but I want the file name too :(
Ticket URL: <http://trac.osgeo.org/postgis/ticket/628>
