[postgis-devel] [PostGIS] #629: Raster ST_Contains
PostGIS trac at osgeo.org
Wed Oct 20 02:43:30 PDT 2010
 Reporter:  andrewsimpson   |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 1.5.3
Component:  postgis raster  |     Version:  1.5.X
 Keywords:                  |
Changes (by jorgearevalo):
  * owner:  pracine => jorgearevalo
  * status:  new => assigned
Comment:
 Hi Andrew,
 ST_Contains considers a polygon doesn't contain its boundaries, and that's
 what's happening here, I think.
 The BOX2D constructed to make the query is based on the pixel corners of
 each block (=row in raster table in tiled rasters) transformed in map
 coordinates using geotransform array. Making a buffer around this box
 could solve the problem, yes, but I think getting a tile per server round
 it's an improvable strategy.
 I have a new version of GDAL driver, with some improvements, but this part
 hasn't be improved yet. Suggestions are welcome before committing it.
 Many thanks for the report, Andrew.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/629#comment:1>
