[postgis-devel] current_parser_check_flags
Paul Ramsey pramsey at opengeo.org
Thu Oct 21 07:27:03 PDT 2010
OK, whew, so I'm not insane :)
Don't bother fixing it, since I'm replacing that parser. I'll go back
to an earlier revision to do my reading.
P.
On Thu, Oct 21, 2010 at 4:49 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> I'm slowly working through getting a new WKT-to-LWGEOM parser in
>> place, and the first steps are the longest, as I have to replicate the
>> behaviour and API of the current parser... so having got to the point
>> of extracting location information and handling error conditions I'm
>> now looking at the parser check flags. And strangely, though I can see
>> quite clearly where the current_parser_check_flags global is set at
>> the start of the parse phase, I cannot see anywhere thereafter that
>> refers to the value of that global. I would, looking at the code, say
>> the checks are being ignored, if not for the fact that I can run SQL
>> and actually see them being applied... so: how does this work? Mark?
>> (Strictly speaking, I don't need to know how the current stuff works
>> in order to make my stuff enforce the checks, but I don't like being
>> ignorant in this way.)
>> P.
> What the heck? The checks have been totally removed?!
> ...goes and looks back over the SVN history...
> OMG. It looks like the entire set of checks got hosed when Mark re-merged
> his parser changes back into trunk (and 1.5) here:
> http://trac.osgeo.org/postgis/changeset/3821/trunk/liblwgeom/lwgparse.c
> This merge is just plain wrong in that it ignores all of the passed flags
> and appears to enforce all checks regardless :(
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
