[postgis-devel] [PostGIS] #610: [raster] Can't build with raster
PostGIS trac at osgeo.org
Fri Oct 22 07:26:17 PDT 2010
 Reporter:  robe            |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by jorgearevalo):
 * cc: jorge.arevalo@… (added)
 With the new release (r6095) to construct the raster stuff you only need
 to do "./configure --with-raster & make & make install". And the library
 object now uses the PostGIS version numbers (2.0)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/610#comment:11>
