[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
PostGIS trac at osgeo.org
Fri Oct 22 21:34:59 PDT 2010
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  PostGIS 2.0.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Paul -- I'll have to check again but even with Mark's patch Ming was not
 happy with your yacc.  I thought maybe it was because my flex and bison
 were kind of old.
 I was running bison 2.0 I think and I upgraded to 2.5.4.
 I forget my flex version, but it didn't seem to like the --case-sensitive
 9compalined of - is invalid command).  I changed to -i (which stopped that
 complaining) but I guess I was getting also an error earlier in bison
 since flex complained the other file was not available.  Anyway I'll put
 up some proper detail later and mark as a non-issue if the problem went
 away with your last patch.  Just wanted to put my foot here before I
 forgot about it.
 Which flex and bison is everyone running by chance?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:8>
