[postgis-devel] [PostGIS] #640: ST_SetPixelSize behaving unpredictably
PostGIS trac at osgeo.org
Fri Oct 22 21:42:37 PDT 2010
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 Okay perhaps it is my misunderstanding.
 I have 2 elephants -- one I brought in whole and one I chopped into
 pieces.
 -- we let this one live
 python gdal2raster.py -r pele.png -I -t ch13.pele -o pele.sql
 - we sacrifice this one
 python gdal2raster.py -r pele.png -I -k 50x50 -t ch13.pele_chunked -o
 pele_chunked.sql
 Both come in upside down, which I assume is becasue I imported with gdal
 1.6.  No problem.
 -- run this command
 UPDATE ch13.pele SET rast = ST_SetPixelSize(rast,1,-1);
 UPDATE ch13.pele_chunked SET rast = ST_SetPixelSize(rast,1,-1);
 The single row whole one flips over correctly to line up with the image as
 I expect.  The second one just shifts down one row.
 I would have expected the sacrificed elephant to also line up with the
 image after flipping.
 See attached files.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/640>
