[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
PostGIS trac at osgeo.org
Sat Oct 23 09:08:25 PDT 2010
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  PostGIS 2.0.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:
Comment(by robe):
 Nope nope,
 but this works:
 flex -olwin_wkt_lex.c lwin_wkt_lex.l
 which gets me a bit further - I wonder if the other errors are similar
 issue.
 flex -i -olwin_wkt_lex.c lwin_wkt_lex.l
 gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes  -c -o
 lwin_wkt_lex.o lwin_wkt_lex.c
 lwin_wkt_lex.c:681: warning: no previous prototype for 'wkt_yylex'
 lwin_wkt_lex.c: In function `wkt_yylex':
 lwin_wkt_lex.c:773: error: `yylineno' undeclared (first use in this
 function)
 lwin_wkt_lex.c:773: error: (Each undeclared identifier is reported only
 once
 lwin_wkt_lex.c:773: error: for each function it appears in.)
 make[1]: *** [lwin_wkt_lex.o] Error 1
 make[1]: Leaving directory `/c/projects/PostGIS/trunk/liblwgeom'
 make: *** [liblwgeom] Error 2
 make -C liblwgeom
 make[1]: Entering directory `/c/projects/PostGIS/trunk/liblwgeom'
 function)
 once
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:13>
