[postgis-devel] [PostGIS] #644: ST_MapAlgebra raster/scripts/plpgsql some broken
PostGIS trac at osgeo.org
Sat Oct 23 15:49:00 PDT 2010
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 -- this is invalid (that should be $4 I believe)
 CREATE OR REPLACE FUNCTION ST_MapAlgebra(rast raster, band integer,
 expression text, nodatavalexpr text)
     RETURNS raster
     AS 'SELECT ST_MapAlgebra($1, $2, $3, nodatavalexpr, NULL)'
     LANGUAGE 'SQL' IMMUTABLE;
 --- this is invalid (it might be because I'm testing on 9.1 (though 9.0
 should have the same issue) since both support named variables function
 call syntax and so are more stringent about naming -
 CREATE OR REPLACE FUNCTION ST_MapAlgebra(rast raster, expression text,
 nodatavalexpr text)
     RETURNS raster
     AS 'SELECT ST_MapAlgebra($1, 1, $2, $3, NULL)'
 gives error
 ERROR:  cannot change name of input parameter "pixeltype"
 HINT:  Use DROP FUNCTION first.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/644>
