[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
PostGIS trac at osgeo.org
Sat Oct 23 17:36:09 PDT 2010
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  PostGIS 2.0.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:
Comment(by mcayland):
 IIRC from reworking the Makefiles for PGXS, the key to making older
 versions of flex read the filename from the command line correctly is to
 wrap the filename in apostrophes.
 So I would try changing liblwgeom/Makefile.in from:
 lwin_wkt_parse.c: lwin_wkt_parse.y
     $(YACC) -o$@ -d $^
 to:
     $(YACC) -o'$@' -d $^
 as per the existing parser Makefile rule.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:17>
