[postgis-devel] [PostGIS] #646: Make functions support named argument call syntax
PostGIS trac at osgeo.org
Sat Oct 23 23:20:24 PDT 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS Future
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I have started to do this with the raster functions by making sure the
 function names given match the documented ones.
 Now that both PostgreSQL 9.0 and 9.1 support named function arguments I
 can only assume peopel will begin to think the argument names we have
 documented in the manual can be used with this syntax.  Of course in most
 cases they can not since many of our functions except for the raster ones
 even use names.
 By named argument call syntax I mean this
 SELECT ST_AddBand(rast:= myrast, pixeltype:='8BUI');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/646>
