[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
PostGIS trac at osgeo.org
Sun Oct 24 11:48:12 PDT 2010
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  PostGIS 2.0.0
 Component:  postgis       |     Version:  trunk
Resolution:                |    Keywords:
Comment(by robe):
 Paul,
 Haven't checked again, but Hudson is having the same issues I had after I
 manually fixed the flex line
   PostGIS is now configured for i686-redhat-linux-gnu
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
  -------------- Dependencies --------------
   GEOS config:          /var/home/buildbot/opt/geos/3.2.0/bin/geos-config
   GEOS version:         3.2.0
   PostgreSQL config:    /var/home/buildbot/opt/pgsql/8.3/bin/pg_config
   PostgreSQL version:   PostgreSQL 8.3.7
   PROJ4 version:        46
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.6.26
   PostGIS debug level:  0
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/sgml/docbook/xsl-stylesheets
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
 ++ grep MAJOR Version.config
 ++ cut -f2 -d=
 + POSTGIS_MAJOR_VERSION=2
 ++ grep MINOR Version.config
 ++ cut -f2 -d=
 + POSTGIS_MINOR_VERSION=0
 ++ grep MICRO Version.config
 ++ cut -f2 -d=
 + POSTGIS_MICRO_VERSION=0SVN
 + POSTGIS_VERSION=2.0.0SVN
 + make
 make -C liblwgeom
 make[1]: Entering directory `/var/home/buildbot/opt/hudson/jobs/PostGIS-
 trunk-build/workspace/src/liblwgeom'
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o stringbuffer.o
 stringbuffer.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o measures.o
 measures.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o measures3d.o
 measures3d.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o box2d.o box2d.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o ptarray.o
 ptarray.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom_api.o
 lwgeom_api.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom.o
 lwgeom.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwpoint.o
 lwpoint.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwline.o
 lwline.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwpoly.o
 lwpoly.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwtriangle.o
 lwtriangle.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmpoint.o
 lwmpoint.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmline.o
 lwmline.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmpoly.o
 lwmpoly.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcollection.o
 lwcollection.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcircstring.o
 lwcircstring.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcompound.o
 lwcompound.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcurvepoly.o
 lwcurvepoly.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmcurve.o
 lwmcurve.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmsurface.o
 lwmsurface.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwpsurface.o
 lwpsurface.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwtin.o lwtin.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwout_wkb.o
 lwout_wkb.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwin_wkb.o
 lwin_wkb.c
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwout_wkt.o
 lwout_wkt.c
 bison -y -o'lwin_wkt_parse.c' -d lwin_wkt_parse.y
 lwin_wkt_parse.o lwin_wkt_parse.c
 In file included from lwin_wkt_parse.y:16:
 lwin_wkt.h:54:57: warning: no newline at end of file
 flex -o'lwin_wkt_lex.c' -i lwin_wkt_lex.l
 gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwin_wkt_lex.o
 lwin_wkt_lex.c
 In file included from lwin_wkt_lex.l:7:
 lwin_wkt_lex.c:690: warning: no previous prototype for ‘wkt_yylex’
 lwin_wkt_lex.c: In function ‘wkt_yylex’:
 lwin_wkt_lex.c:782: error: ‘yylineno’ undeclared (first use in this
 function)
 lwin_wkt_lex.c:782: error: (Each undeclared identifier is reported only
 once
 lwin_wkt_lex.c:782: error: for each function it appears in.)
 make[1]: *** [lwin_wkt_lex.o] Error 1
 make[1]: Leaving directory `/var/home/buildbot/opt/hudson/jobs/PostGIS-
 make: *** [liblwgeom] Error 2
 I'm beginning to wonder if its just the order of the includes.  Last I
 checked my build was creating these files (I even tried to upgrade my
 bison to the same version 2.4.2 -- though that was a royal pain it finally
 took) and it didn't help the situation.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:19>
