[postgis-devel] SnapToGrid higher dimensions (was: measures test fail)
Nicklas Avén nicklas.aven at jordogskog.no
Mon Oct 25 02:46:39 PDT 2010
you have a good point there ...
On Mon, 2010-10-25 at 11:39 +0200, strk wrote:
> On Mon, Oct 25, 2010 at 11:30:55AM +0200, Nicklas Avén wrote:
> > well, problem and problem.
> > I think most people expect when they do what you did in r6083
> > http://trac.osgeo.org/postgis/changeset/6083 that also z will be
> > snapped. Of course we can not always meet peoples expectations, but when
> > it is possible it makes the software very much more easy to use. All
> > remembering of special rules for special functions makes things more
> > difficult. From that perspective, when everything in the code is
> > prepared for z and m snapping except the part in LWGEOM_snaptogrid where
> > z and m grid values are set to 0, I thought it would have been nice to
> > get all dimensions snapped when writing ST_SnapToGrid(the_geom, 0.01)
> > I think your suggestion is quite appealing, eventually with just a
> > special case for the example ST_SnapToGrid(the_geom, 0.01), since I
> > think that is the most common usage and that wouldn't conflict with
> > anything in overloading the function.
> Uhm...
>  ST_SnapToGrid(the_geom, 0.01) snapping all dimensions ?
> X and Y might be lon,lat while Z could be meters...
> M go figure out what it is...
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
