[postgis-devel] [PostGIS] #650: st_dumpaspolygon create int values
PostGIS trac at osgeo.org
Mon Oct 25 11:36:29 PDT 2010
 Reporter:  etiennebr       |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 1.5.3
Component:  postgis raster  |     Version:  1.5.X
 Keywords:                  |
 SELECT ST_AsBinary((ST_DumpAsPolygons(rast)).geom),
         (ST_DumpAsPolygons(rast)).val
 FROM smallr
 Returns grouped values at the integer value. Is it possible to specify to
 return three digits values ?
 Using let'say
 SELECT ST_Value(rast,10,15)
 FROM smallr
 Returns 32B floats values
Ticket URL: <http://trac.osgeo.org/postgis/ticket/650>
