[postgis-devel] [PostGIS] #1133: Figure out and approve library dependency strategy.
PostGIS trac at osgeo.org
Tue Oct 19 13:54:19 PDT 2010
 Reporter:  bnordgren  |       Owner:  pramsey
     Type:  task       |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by bnordgren):
 Essentially. But without actually resampling. GDAL has an "image to image"
 transformer, which calculates the (i,j) index of one image using the (i,j)
 index of a second image. This needs the projections (SRS) of the two
 images.
 However, once a strategy is figured out, it has much wider applicability
 than this first application. Raster suddenly has access to all Postgis
 functionality at the C level.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1133#comment:4>
