[postgis-devel] Small regression test updates
Andreas 'ads' Scherbaum adsmail at wars-nicht.de
Wed Oct 20 01:27:31 PDT 2010
Am 20.07.2011 08:23, schrieb Sandro Santilli:
> On Tue, Jul 19, 2011 at 10:25:29PM +0200, Andreas 'ads' Scherbaum wrote:
>> Attached you can find a small patch which adds "order by 1" in some
>> of the regression tests, and also changes the output order in some
>> of the .expected files. The data itself is not changed. The patch
>> works with PostgreSQL 9.04 and PostGIS 1.5.3.
> Wouldn't it be safer, at that point, to order by a real column ?
The SQL standard allows numbers for the columns.
Plus then you end up with a sql like:
order by "<function name>"
Here is a description from the SQL92 standard:
          13.5  <select statement: single row>
          Function
          Retrieve values from a specified row of a table.
          Format
          <select statement: single row> ::=
               SELECT [ <set quantifier> ] <select list>
                 INTO <select target list>
                   <table expression>
          <select target list> ::=
               <target specification> [ { <comma> <target specification>
          Syntax Rules
          1) The number of elements in the <select list> shall be the
             same as the number of elements in the <select target list>.
             The i-th <target specification> in the <select target list>
             corresponds with the i-th element of the <select list>.
Life's easier, if you don't have to care about the column names.
Regards,
German PostgreSQL User Group
European PostgreSQL User Group - Board of Directors
Volunteer Regional Contact, Germany - PostgreSQL Project
