[postgis-devel] Test: tin_tgeom throws segmentation fault
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Wed Sep 1 05:29:09 PDT 2010
Olivier Courtin wrote:
> On Aug 31, 2010, at 6:35 PM, Mateusz Loskot wrote:
> Hi Mateusz,
> > FYI, building PostGIS from the trunk r5875 under Linux 64-bit
> > using GCC 4.4.3:
> Ok many thanks for the report,
> It should be fixed as r5878
Olivier, I confirm it's been fixed.
Thanks!
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the  original intended recipient. If you have
received this email in error  please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
