[postgis-devel] [PostGIS] #581: LWGEOM_expand produces inconsistent results
PostGIS trac at osgeo.org
Thu Sep 9 12:35:01 PDT 2010
 Reporter:  alexz    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by alexz):
 That patch doesn't change the results of the query in the body of the bug
 report for me.
 Because I had to blow away the database for other reasons I took the
 following steps:
 Patch postgis.
 Install postgis.
 Restart postgres.
 Create new database with SQL files from the postgis install.
 Run said query.  One column is true, one false.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/581#comment:6>
