[postgis-devel] [PostGIS] #582: [wktraster] Correct pixel size calculations
PostGIS trac at osgeo.org
Fri Sep 10 07:34:40 PDT 2010
 Reporter:  dzwarg     |       Owner:  dzwarg
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  1.5.X
 Keywords:             |
Comment(by dzwarg):
 Well, skewx and skewy may be unequal for small rotations. The ratio of
 skewx / scaly and skewy / scalex remains constant, though.
 I do know what you refer to, though -- when a raster is indeed skewed, or
 diamond shaped, there are really 2 rotations; one for the amount off the X
 axis, and one for the amount off the Y axis.
 Would it be acceptable if ST_Rotation returned NaN for conditions when
 non-uniform rotations are detected, and was documented as such?
 I agree that st_setrotation doesn't have this problem, since you are
 setting the skew/scale for both dimensions at the same time.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/582#comment:3>
