[postgis-devel] [PostGIS] #585: Error running topology.sql
PostGIS trac at osgeo.org
Fri Sep 10 15:21:51 PDT 2010
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  1.5.X
 Keywords:             |
 Try-ing to install the topology module,
 when I try to run
 make
 psql -h localhost -f topology.sql
 I have an error and all rollbacks.
 psql:topology.sql:676: ERROR:  syntax error at or near "table"
 RIGA 60:    || quote_literal(table) || '',''
 psql:topology.sql:683: ERROR:  current transaction is aborted, commands
 ignored until end of transaction block
 psql:topology.sql:784: ERROR:  current transaction is aborted, commands
 I'm using
 postgres 9.0rc1
 postgis r5960
 geos r3104
 on Debian 5.0 Lenny 32 bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/585>
