[postgis-devel] WKTRaster Scale and Skew
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Sep 14 08:19:00 PDT 2010
So in the end, what are the proposed changes from the users point of view (in rtpostgis.sql)? Sorry I have been away a bit.
Pierre
From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of David Zwarg
Sent: 10 septembre 2010 11:35
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] WKTRaster Scale and Skew
On Fri, Sep 10, 2010 at 11:16 AM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca<mailto:Pierre.Racine at sbf.ulaval.ca>> wrote:
>  Width is computed based on scale & skew?
In 99% of the cases there is no rotation and pixel width & height ARE synonyms for scale X and scale Y. Is it worth changing their names? Adding confusion? How does GDAL name it?
I agree that 99% of the time, there is no rotation.  I don't propose changing the names of the pixel width methods, just change the way it is computed to account for the skewing.  I wouldn't mind hiding the set_skews() method, in favor of accepting all adjustments in the form of the georeference string.  This is the way GDAL gets around it -- they don't name the 6 components of the georeference, and just note that "In case of north up images, the GT(2) and GT(4) coefficients are zero" -- not much help if you want to know what happens when north is not up.
>We don't call it scaleX and scaleY, but cell_width_x and cell_height_y
>We don't call it skewX and skewY, but cell_width_y and cell_height_x
In rt_api.c? Why not...
>We separate the accessors for the pixel width and the georeference component that is now used as the width.
You mean creating a "truepixelwidth" function? Same reluctance since it is not really a width when the pixel shape is a diamond. But you could say "this happen only 0.001 of the time"... Does that mean removing or renaming the ST_PixelSizeX and ST_PixelSizeY function?
I would propose some other name besides pixel 'width', since it's only a part of the width.  Maybe we don't have any accessors for this value at all, and the only way to get it is through the georeference string?
>Tests assume the upper left coordinate is SMALLER in the X and GREATER in the Y for all other coordinates in the raster -- this would require adjusting our tests to handle the coordinate space uniformly.
Ok.
My main concern is to not confuse users with scale, skew and width. Most people know only pixelsize.
I agree -- it took me a few minutes to understand that the parameters are not exactly width or scale or skew.  This may be sacrilege, but what if all that was hidden under the hood, and we just provide the true width/height get functions and the get/set functions for the georeference?  Because most of the time, nobody will care about the skew.
Thoughts?
Zwarg
Pierre
postgis-devel mailing list
postgis-devel at postgis.refractions.net<mailto:postgis-devel at postgis.refractions.net>
http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100914/a5800c03/attachment.html>
