[postgis-devel] [PostGIS] #593: [raster] Add a ST_BandIsNoData function
PostGIS trac at osgeo.org
Wed Sep 15 09:10:04 PDT 2010
 Reporter:  pracine         |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 Returns true if and only if the band is filled only with nodata values.
 This function is usefull to optimize many functions.
 This function requires a new flag (similar to the hasnodatavalue flag) to
 be set a the band level.
 Change to the loader are also required. Any editing function changing a
 pixel value from nodata to with data should also reset the flag.
 We might want to add a ST_ResetBandISNoData function later.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/593>
