[postgis-devel] [PostGIS] #587: [raster] SVN copy wkt raster code to PostGIS trunk
PostGIS trac at osgeo.org
Fri Sep 17 10:59:03 PDT 2010
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 Do I have to merge PostGIS "configure.ac" with WKT Raster "configure.ac"?
 That's: is WKT Raster going to be compiled by default when compiling
 PostGIS?
 - If yes: I should merge both configure.ac scripts. Pay attention to the
 fact WKT Raster needs GDAL, and this can't be a constraint for normal
 PostGIS compiling.
 - If not: The user must execute "./configure & make & make install" both,
 in general PostGIS folder and in "raster" folder inside PostGIS one.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/587#comment:6>
