[postgis-devel] [PostGIS] #565: shp2pgsql-gui crashes when selecting second file
PostGIS trac at osgeo.org
Sat Sep 18 08:26:40 PDT 2010
 Reporter:  robe     |       Owner:  mleslie
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by mcayland):
  * owner:  pramsey => mleslie
Comment:
 FWIW I also see at least 2 other bugs with shp2pgsql-gui in trunk:
 1) When launching from the command line, I get lots of errors similar this
 appearing before the main dialog appears onscreen:
 (shp2pgsql-gui:7943): Gtk-CRITICAL **: gtk_list_store_get_value: assertion
 `column < list_store->n_columns' failed
 (shp2pgsql-gui:7943): GLib-GObject-CRITICAL **: g_object_set_property:
 assertion `G_IS_VALUE (value)' failed
 (shp2pgsql-gui:7943): GLib-GObject-CRITICAL **: g_value_unset: assertion
 2) If I click on the "Test connection" button, even if the connection
 fails then the dialog and log window both display "Connection succeeded".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/565#comment:1>
