[postgis-devel] [PostGIS] #603: shp2pgsql: "-w" produces invalid WKT for MULTI* objects
PostGIS trac at osgeo.org
Sun Sep 19 09:45:05 PDT 2010
 Reporter:  mwtoews    |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:  shp2pgsql  |
Comment(by mwtoews):
 The patch works to produce usable SQL that is successfully loaded into
 postgres.
 #!sql
 INSERT INTO "foopoly" ("fooname",the_geom) VALUES
 ('triangle',GeomFromText('SRID=26910;MULTIPOLYGON(((-0.573744292237443
 0.445890410958904,-0.436301369863014 0.257305936073059,-0.660045662100457
 0.209360730593607,-0.573744292237443 0.445890410958904)))', 26910));
 INSERT INTO "foopoly" ("fooname",the_geom) VALUES ('split
 shape',GeomFromText('SRID=26910;MULTIPOLYGON(((-0.100684931506849
 0.365981735159817,-0.0335616438356166 0.199771689497717,-0.209360730593607
 0.225342465753425,-0.100684931506849
 0.365981735159817)),((-0.212557077625571
 0.190182648401827,-0.0367579908675799 0.161415525114155,-0.167808219178082
 0.0463470319634702,-0.212557077625571 0.190182648401827)))', 26910));
 However I get this warning for each feature (twice for :
 WARNING:  OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
 I think a better patch would set SRID = -1 for all geometries (not just
 inner). But a warning is fine at this stage.
 Regarding the future of this feature: I don't rely on it, but I've found
 it helpful for some debugging. I won't miss it if it is removed for v2.0.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/603#comment:5>
