[postgis-devel] State of shp2pgsql-gui in trunk
Mark Leslie mrk.leslie at gmail.com
Mon Sep 20 18:22:10 PDT 2010
Mark,
I'm going to try and step up my game to bring this work up to speed
and continue to maintain it, but as I'm sure has been noted, I'm doing
a poor job of this lately.  If I prove insufficient, let me know and
I'll roll it back and stuff it into a spike or similar.
Mark
On 19 September 2010 22:55, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Hi folks,
> Having just been applying fixes to shp2pgsql-gui in both trunk and 1.5, I am
> getting quite concerned about the state of shp2pgsql-gui in trunk. Here are
> a few of the issues I have noticed with current trunk:
> - Multiple warnings at build-time
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes
> -I/home/pg83/rel-8.3.7/include -D_REENTRANT -I/usr/include/gtk-2.0
> -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo
> -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
> -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb
> -I/usr/include/libpng12    -o shp2pgsql-gui.o -c shp2pgsql-gui.c
> shp2pgsql-gui.c:155: warning: no previous prototype for ‘pgui_log_va’
> shp2pgsql-gui.c: In function ‘compare_columns’:
> shp2pgsql-gui.c:1000: warning: enumeration value ‘FTInvalid’ not handled in
> switch
> shp2pgsql-gui.c: In function ‘pgui_create_file_table’:
> shp2pgsql-gui.c:2369: warning: unused variable ‘bin_window’
> shp2pgsql-gui.c: At top level:
> shp2pgsql-gui.c:1675: warning: ‘pgui_action_null’ defined but not used
> shp2pgsql-gui.c: In function ‘pgui_action_shape_file_set’:
> shp2pgsql-gui.c:1713: warning: ‘status’ may be used uninitialized in this
> function
> shp2pgsql-gui.c: In function ‘pgui_action_handle_tree_edit’:
> shp2pgsql-gui.c:666: warning: ‘status’ may be used uninitialized in this
> function
> - Multiple GTK assertions triggered at run time
> e.g.
> (shp2pgsql-gui:29945): GLib-GObject-WARNING **:
> /build/buildd-glib2.0_2.22.4-1~bpo50+1-amd64-SJ3EDw/glib2.0-2.22.4/gobject/gsignal.c:2270:
> signal `changed' is invalid for instance `0x6becc0'
> (shp2pgsql-gui:29945): GLib-GObject-WARNING **: IA__g_object_set_valist:
> object class `GtkCellRendererToggle' has no property named `editable'
> (shp2pgsql-gui:29945): Gtk-CRITICAL **: gtk_list_store_get_value: assertion
> `column < list_store->n_columns' failed
> (shp2pgsql-gui:29945): GLib-GObject-CRITICAL **: g_object_set_property:
> assertion `G_IS_VALUE (value)' failed
> (shp2pgsql-gui:29945): GLib-GObject-CRITICAL **: g_value_unset: assertion
> - Bitrot/regressions compared to 1.5 branch
> It looks as if the merge into trunk has removed some of the later changes
> from the 1.5 branch, e.g. take a look at pgui_read_connection(). The version
> in trunk has now regressed to a much older version, and is totally different
> from the logic in the 1.5 branch. Does that mean that there are other
> instances of this from the merge?
> - Test connection always displays "Connection Succeeded" even when it
> doesn't?!
> - General code quality issues:
> Random bits of code are commented out with no explanation, e.g shp2pgsql-gui
> lines 43-46, and lines 1176-1179. These sections need to either be fixed up
> or removed. Also what does the sqlform query do? It's not obvious and needs
> a comment. Some sections of code are still marked TBD.
> To summarise, my feeling is that in its current state this code is not ready
> for the prime time, and the maintenance is going upwards due to trunk not
> being based on a recent version of 1.5 branch. I think someone needs to step
> up to fix/maintain this code ASAP or we should simply revert the changes and
> re-synchronise with the 1.5 branch :(
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
