[postgis-devel] [PostGIS] #607: 6 regression tests failed with PostGIS SVN version
PostGIS trac at osgeo.org
Tue Sep 21 09:31:12 PDT 2010
 Reporter:  jorgearevalo  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 2.0.0
Component:  postgis       |     Version:  trunk
 Keywords:  regress test  |
 6 tests failed: regress, wkt, measures, sql-mm-compound-curve, sql-mm-
 curvepoly and tickets
 My enviroment: VMWare machine running Ubuntu 9.10, PostgreSQL 8.4.4, GEOS
 3.3.0, PROJ4 4.7
 Attached the 6 diff files generated.
 Has anyone the same problem?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/607>
