[postgis-devel] Testing on Windows PostGIS 1RC1
Nicklas Avén nicklas.aven at jordogskog.no
Tue Sep 21 23:54:27 PDT 2010
I will try to do some testing this evening.  I tried yesterday on windows but had problems with compiling postgresql 9.0I don't remember the error message now. I will try on another box. Regina has there been any special things compiling 9.0 in mingw for you? I have not updated anything (have just been glad it has worked :-)  )so maybe I should just reinstall mingw and everything. /Nicklas
2010-09-22 Paragon Corporation wrote:
>> Remember that because postgis_comments.sql has extra dependencies for the
>documentation build that it needs to be installed from the documentation
>Makefile. This is now under PGXS control too, so all you need to do is:
>> cd doc/
>> make comments-install
>> ...and you're golden.
>For this then we probably should put a note somewhere in the docs that if
>they aren't doing a make install of comments, then the comments will have to
>be manually copied.
>The point why we package the postgis_comments.sql in the tar is so that
>people don't need the extra xsltproc dependency and don't need to run the
>step you describe above. So yah I know the step above works but that is not
>the point.
>I'll have to get back to you other issue as I don't have my difffs around.
>All I recall is the output was something like
>SELECT 3456
>And the regress just had
>SELECT
>But lets see what others say. We are on windows so who cares since things
>don't quite work the same for us anyway.
>Thanks,
>Regina
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100922/1a2c9599/attachment.html>
